'90 Battery Drain--Hatch light fuse?
propagandhi
Car: 1990 Nissan 240sx
My battery keeps dying, it won't even last for 3 days on a full charge. I found that the light in the hatch/trunk doesn't turn off because the hatch doesn't close all the way, but it does turn off when you push down on the hatch.
Does anyone know if there is a fuse I can pull for this light?
Or a quick fix of the hatch that will cause it to turn off?
Update: So, I pulled the "Room Lamp" fuse (third one down on the right) and it was for the hatch light, but also the clock, seat belts, cd player etc. Can't be having that.
How can I fix my hatch so that it switches the light out?
Modified by propagandhi at 7:54 AM 4/25/2009
