90-96 Radiator fan same?
JT_MONEY_2004
Car: 1990 Q45, Pearl
Are 90-96 Radiator fans interchangable or not. Which ones will work in my '90 std Q?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Pretty sure that 90-93 and 94-96 are different as they have different shaped fan shrouds...
qship96
Car: 1996 Infiniti Q45
same fan blade for 90-96q
ProperQ
Car: 1994 Infinity Q45t
I just replaced mine a week or two ago $90 at the dealer in a crunch but better than fan pieces flying threw something serious. Ill check my reciept to see if it say's the years or something.
elwesso
2007 BMW M Coupe
qship96 wrote:same fan blade for 90-96q
Wrong.....
90-93 part number is: 21060-60U0094-96 part number is: 21060-0P500
Not to say they are not interchangeable, but they are not the same.
Q45tech
Fan shroud is different also............an improved design to increase summer low rpm cooling. Just as radiators are different [dual vs single AT heat exchanger].
Multi- thousands of components are different on 94 and later.
The 94 has so few major components that are interchangable you can count them on 2 hands and 2 feet........ upper links, tension rods, 3rd link, rear shocks, rear suspension links shafts without TCS, drive shaft, motor mounts, alternator, wheel bearings, kingpins, door hinges,
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Q45tech wrote:Fan shroud is different also............an improved design to increase summer low rpm cooling. Just as radiators are different [dual vs single AT heat exchanger].
What was the first year for the dual heat exchanger? Many other parts are interchangable but they many appear or function differently or require minor modification.
elwesso
2007 BMW M Coupe
94... Im pretty sure anyway
JT_MONEY_2004
Wes how do you find the part #'s so efficiently? I doubt you calling the dealer...at least i hope not. Dealer's website usually wont say the part #'s
Thanks, so i couldnt buy yours anyway huh, and i was coming around to spending that $50. Thanks.
When i did some cooling system work, i found that my fan had many...to the tune of 12-14 cracks in it. I NEED A BLADE NOW. There simply aren't any Q's in my area, one guy wanted to know who makes INFINITI's.
elwesso
2007 BMW M Coupe
JT... I have the dealership parts book on my computer......
Im sorry if when you were trying to buy my fan i seemed like I was blowing you off... But i didnt think it would work, but i never got around to confirming.....
JT_MONEY_2004
Cool.I'll keep posting, till somebody sells me one, hopefully SOON.
qship96
JT_MONEY_2004 wrote:Cool.I'll keep posting, till somebody sells me one, hopefully SOON.
Joe would be happy to sell you one TODAY! a brand new one,with a full life ahead of it to protect your engine from overheating and the cost of body work and paint to the hood if yours ,or most likely another old used one you buy secondhand decides to blow apart from the age/heat induced cracking! at joes price for this important part,consider it cheap insurance!
hal90000
Car: 1996 Q, 102,000 miles as of mid 2009
Just bought mine from Joe. $64.30 delivered. Noticed the fan was cracked when I replaced the alternator belt and idler pulley last week. Which I also bought from Joe. Ordered the fan on monday and will receive on Friday.
