90-93 vh45 DLC wiring diagram
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
can anyone post a copy of the data link connector wiring diagram for 90-93 Q45's? i cant communicate with my ecu via either dlc in my car!
car: 96 240
ecm: 91 q45; chipped and tuned by carl H
wiring harness 94 q45; conversion done by carl H
so i can power up the consult via the consult dlc (grey connector near fuse panel) and can only access my airbag module. not the ecm. i have the wiring diagram from the car's dlc and for a 94 q45 dlc but it shows the ecm connectors to be totally different and as well the 94' Q only shows the generic obd2 dlc not the consult dlc (grey connector). if anyone has any helpful info i would greatly appreciate it!
:wtf2: :wtf2: :wtf2: :dblthumb: :poke:
Q451990
Does this help?
http://www.allpinouts.org/index.php/Nis ... _PC_serial
Are you using a real Consult, or one of the aftermarket kits?
Heath
newbissan-tech
I'm using a real consult2 I work at the Nissan dealer
And your diagram just shows consult to a pc serial cable? I need the fsm diagram of the consult port to the ecu on a 90'-93' Q45? But thanks for the info looks to be very useful for wiring up your own consult cable!
Q451990
Oh I see.
Does this help? These are scans out of the '91 FSM.
https://docs.google.com/viewer?a=v&pid= ... y=CMKEhpsE
Heath
newbissan-tech
Yes and no but I figured it out, in the assist the ECM pinout for a 94' Q45 is a misprint and the 95' Q45 ECM printout is correct
Q451990
Glad you got it... hit me up if you need anything pre-1994 scanned and posted.
Heath
Return to “VH45DE / VK45DE / VK56DE Forum”
