rotarius wrote:newbie warning. I just got an 90 Q45 and the tension rods are cracked. did some searching and it seems like z32 300zx or s14 240sx rods may fit. The reason i ask is q's are rare in the junk yards and i would like to increasethe possibilities. can anyone verify that?is there an cheap way to fix the tension rods? thnx
The bushings can be replaced, but that requires a press ... sometimes NAPA will do that for you.
IIRC, the other tension rods you mentioned will work, but only if they're the adjustable kind.
