kdkrone wrote:There are annoying black plastic clips that hold the fiberboard covers in place over the headlights and between the radiator and the hood latch on my Q. The dealer says that they are $2.42 each(!), but he can't even obtain them. I can't help but think that they are a common enough item that they must be available as a generic item.
Does anyone have a source for these annoying objects??
ThanksKen K
I used these once they all stripped out and pissed me off...The part # should be good when you call up a parts store Partsamerica shows some.... Work a lot better than the &$*%$*^%#$#@#@screw thing since you pull up on the middle button with a tack puller or something. Cheap too!!! $5-6 a box !!
My car hasn't blown up or started on fire yet. So these must be approved by the Infiniti gods (the real ones not Brian) since I felt the rain of blessings once they were in.... EDIT:One of these ought to work fine.
http://www.dormanproducts.com/...=Body Fasteners,Specialty Rivets&st_amount=0&end_amount=999999999.99&start=36&vfrom=&prev=yes&vnext=yes&category_list=1324:314:0
http://www.dormanproducts.com/...=Body Fasteners,Specialty Rivets&st_amount=0&end_amount=999999999.99&start=72&vfrom=&prev=yes&vnext=yes&category_list=1324:314:0
Modified by squeefoo at 5:00 PM 9/12/2006
