Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Mon Sep 30, 2013 8:30 am
On 92 Q45, I'm reinstalling original rail w Deatschwerks purple injector conversion. It's been too long to remember the stackup of the bolt with two captive flat washers, black plastic spacer, rail mounting tab, loose flat washer, and other plastic spacer.
The only thing I'm guessing about is the loose flat washer, 'seems plain enough that there would be black spacer above and below the rail tab, but I cannot remember or reason where the loose flat washer would go.
My guess is, starting with the mounting surface and working up would be mounting surface, black spacer, rail tab, flat washer, black spacer, then the bolt with two captive washers.
If anyone can confirm or deny, 'twould be helpful. Thanks, Drake.
PS I'm tempted to seal rail to runner donuts, they fit rail snugly, but seem slightly loose in the runners. I can't see what a 1/16th" bead of RTV around the outside would hurt. Has anyone tried same?
