thanks for the heads up on the tension rods. this is my 92 as it sits right now:
i have many ideas in mind but the goal is to bring it back to its luster with some upgrades to improve performance, comfortability and reliability...........hopefully. i love this car. the way it rides though a little soft due to needing bushings, especially that one at the front of the rear subframe. i love the way it sounds and for a heavy car, it moves like it's a thousand pounds lighter. my reason for asking about the compat of the two models is , though my frame is free of any heavy rust, just light flecks, my removable parts like hubs, links and arms are peeling from it. these items need replacing. and in the pick and pull, im seeing 5-1 ratio of 94-96 model year q45's.
so far what ive done to the car is topend rebuilld consisting of hoses, sensors, 94 injectors and rails,VC's and plugs aswell as guides. recently got the transmission shifting into 4th and now able to manual shift. turns out the inhibitor/range switch wires were melted together and the reverse lights wires were pinched, hence no reverse lights. asked for advice some time ago about the transmission shifting problems. one person swore to GOD the transmission was toast and the other one advised me to sell it and get a 94-96
so if your transmission is shiffting funny, check your switch on the side of the transmission, wires and all before giving up on it. now even though she shifts pretty good, i still feel its a tad bit slow going into 4th and lockup. no telling how long the previous owner drove the car like that. im thinking solenoids need changing. but first my plans are to change transmission fluid, external filter and add transmission plate/fin cooler this weekend. ive installed the nico ecu, 94 tcu, and am at the a** end of a interior swap to grey 94-96 and a 94 sunroof frame. original frame was seized from rust due to leaks now fixed. my only turn off about this car is the fact you have to do a lot to do a little in repairs. i mean VC's required the removal of the whole top end. luckily i was already doing other stuff. oil pan requires a partial lift and seperation of the engine cradle? i dont like it. recently paid to have the rack swapped out becuase i saw it as a b**** to do on the ground not to mention the possible rust buildup giving me problems.good thing is it only cost me $200 for the swap and $170 for the rack and z32 bushings. what i want to do is refurbish the suspension parts including sub frame with 94-6 parts. get new blue shocks, converted to air bag springs. get me another 92 transmission and rebuild with some level 10 goodies and rebuild the short block. ive read on here people saying the engine cant be rebuilt. if the short block does not need machine work, why cant new bearings and rings be installed?? everything else is gaskets and hardware torqued correctly. is that really more expensive than a jdm engine? i also want to play around with my lighting such as led tails, markers and projector headlight. but im still trying to decide if i want to swap the front end over to 94/6 or leave it be. btw, does anyone know the cfm rating on the mechanical cooling fan? mine is off, you guessed it, a 94'
some of you probably feels i should trade for a 94 instead. why? my car is payed for, i know everything wrong with my car, i drive it everyday, and the 94-96 loses a bit of that hotrod edge with the transmission change and other things.
