nisstech »
https://forums.nicoclub.com/nisstech-u5336.html
Fri Apr 11, 2003 6:54 pm
Not a real good idea to just replace just the ball joints. The older nissan max had aftermarket ball joint from napa and others of the sort. By customer request I installed a set. Thay did not fit tight into the hole and worked out. Had to mig weld 4 spots around the joint(removed rubber boot). 3 months later the customer came back with a noise , bushing on the control arm wore out. Just spend the 120.00 or so and do it right. Don't be penny wise and dollar foolish.
