z32partsmo »
https://forums.nicoclub.com/z32partsmo-u152685.html
Mon Mar 22, 2010 9:08 am
Hey I just that i would give you an update. The car has been dying on me a lot more recently. I'm not going to drive it anymore untill I get it fixed. I had to get towed the other day. So I rolled up my sleeves and got to work. Like you said the wire harness is a disaster. I didnt replace it, but I cut out all the butt connectors and soldered and heat shrinked everything to ensure perfect connection. I found several wires that pulled out of the crimped connections, so I was sure this was the problem, but it wasn't. lol So then I continued working and pulled all the coil packs. the two rear cylinder coil packs broke in half as I removed them. Surely this was the problem!! So I was pretty excited. Installed new Platinum plugs and 2 new coils for the rear cylinders. Time to try it. Cranked and started right up first time ran awesome idle perfect.Better than ever before. Big grin on my face. I fixed it!!! 15 minutes later it died. lol I was pissed. So I was wondering if I should replaced the knock sensor ? If its bad it may be sending error to ecu and shutting the car down. what do you think?
