300zxtillidie »
https://forums.nicoclub.com/300zxtillidie-u230561.html
Fri Apr 11, 2014 2:24 am
So the past couple months I've been in the process of resurrecting the NA with a/t after it was left in the unreliable possession of an idiot who couldn't tell his own a** from a hole in the ground. Basically have rebuilt the whole top end and replaced and/or cleaned up everything I can think of aside from a new engine bay wiring harness. So here's the problem, when I'm driving it just doesn't want to shift when it's supposed to unless I get on it and then seems to respond a lot better but not perfect. Ecu has codes 34 and 42. The knock sensor has been cut and dangling since day one, and the fuel temp sensor circuit I gotta do some testing of the wires back to the ecu. Don't think they are related to my current shifting issues, but you never know with these cars. And also have ran Diagnostics on the TCU and the only code I get is for the throttle sensor circuit. I've had several other Z owners/enthusiasts tell me to try checking the shift solenoids even though I'm not getting any codes or MIL lights. And also when attempting to switch from D to 2 or 1 there's no difference in engine behavior. But my Lil bro's grand prix just jumped timing so I gave him my camry that I had been using for a while. So my Z is now my daily, and with gas prices where they are I can't afford to be rolling around everywhere I go at 3-4000 rpm. Any suggestions or ideas on what to check and best way to do so without pulling the transmission would be greatly appreciated!!!
