everpresentnoob »
https://forums.nicoclub.com/everpresentnoob-u268012.html
Wed Nov 09, 2016 9:38 am
You sure you dont want to start a thread about this in the classifieds as well? No need to make multiple posts in all parts of the forum for one issue. Just bad form in general my man...
Now on to the issue... I havent pulled my pump, but basic trouble shooting would be check for power at the pump. make sure connections are clean and tight. If no power there, check your fuses. I believe it is under the hood near the battery. Dont quote me on that location though....
IF you pump is getting power, again knowing that I have NOT pulled a pump in these cars so am unsure how it is set up in the tank, make sure the fuel is able to get through the pump. if you have fuel flow at pump, pull the hose from the finter and ensure you have flow through the filter. IF your last pump died it could have sent crud through the line and clogged the filter. make sure you have good flow there.
With yo saying that your not hearing it prime leads me to thnk its a power issue, so check that first.
