Aaron2355 wrote: I had radiator replaced and changed oil and transmission fluid but since then I think I have major problems.
I was under the impression that you had. Check it and then tell me what color it is. If it has an odor or texture, describe them to me please. I'll try to help. Also, it may not be an electrical problem. If the fluid is black and gritty and smells burnt then you should rebuild your trans. I'm unsure how many miles it has on it but also check for leaky gaskets as low fluid level may not be able to maintain sufficient pressure at lower RPM to hold the gear. Also, if the trans is elecronically controlled, check the shift solenoids for proper operation. This may be difficult but it may be easy. I have been workig w/ american trannys so I am unsure how these Nissan transmissions are designed. If all else fails, have a certified technichian hook it up to a scan tool and pull the Diagnostic Trouble Codes (DTCs) and see where yo can go from there. Oh yeah, usually the solenoids make a noise (depending on the car) and may be heard if the solenoids are external. The easiest thing by far to check is the fluid so start there.
P. S. Oh, BTW, I am having roughly the same problem w/ my chrysler. Yeah, its a MOPAR but its reliable. Over 100K on it and just now giving me probs.
Modified by inquisitorof240 at 9:52 PM 8/2/2006
