MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Tue Nov 12, 2002 9:45 am
eah... you need an FSM... Chiltons suck. I would say that the code 21 might be the source of your dilemma. Although, if you are getting a spark, then one would assume it should fire. If you know the injectors are working properly, then you are getting adequate fuel delivery... this is proplexing to say the least.
It is possible that the old (I'm assuming falty) ignition coil sent the ECU trouble signal, and it won't allow the engine to turn over until the ECU is reset. I'm not sure WHY this would be the case, but it's entirely possible.
Try posting this question in the On-line mechanic forum. Dr.john is a damn genious, and I'm sure he'll have ananswer.
For now, I'd reset the ECU and try again.
