gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Mon Apr 04, 2005 5:34 am
90 240sx 118,xxx miles. Bought it about a month ago.
I recently bought some 16" wheels with 205/55-16 tires on them. When I put them on my car I noticed when I'd go over a bump on the left side of my car, it would sway to the right a little bit - almost sliding (unintentionally).
This went on for a while before I decided to rack it up at my buddies shop and do a differential service (didn't think this was related to it though). While it was up, I noticed that the left front strut was extremely close to the tire (the portion where the spring sits). I couldn't even fit my index finger between the strut and the tire. Then I looked at the right side, I could comfortably slide all 4 of my fingers back and actually touch the strut.
Looking at the left strut, it's obvious that it was rubbing on the tire, probably when going over even the slightest bumps - which was causing the swaying - sliding. I didn't notice this at all when I first bought the car (with the stock 15" w/ 195/60-15's.
In fact, the only thing I can fit on the left side front is the stock tire. I put a 195/65-15 on that side and it rubs just as much as the 205/55-16 does.
Question: Does this mean (in most cases) I need to replace the struts, or could there be someting else involved as well?
Advice needed: I was planning on getting some KYB AGX adjustables along with the Eibach pro-kit springs. I'm now questioning if it's really necessary to get adjustables as I don't feel I'll be adjusting often if ever. I don't street or competition race, so I don't know if it's even necessary. However I do want to lower the car just enough to rid myself of the infamous gap. What's the best way to do this without buying unnecessary things? I would also like to prevent the possibility of "bottoming out" when modding the suspension.
As always, your answers and input are appreciated
