90 240sx Starter problem!
Kraayl
Car: 89 240 coupe!
I have around 3 minor but really irritating problems. So my car wont start when i turn the key, but i hear it click. If i run a wire from the battery to the starter it turns over. The relay to it is good. Bad ground? I really need some help on this.
MaximA32
I would definitely check the grounds and I would also check the connections on the starter on itself. Check the starter solenoid as well.
vancouverbc
Car: 1991 240sx
where exactly did you hook up the battery to? look up the starter tutorial in my signature.
if you hooked it up to ignition wire you have a problem somewhere in the ignition line. ignition switch. interlock relay, wiring. clutch interlock switch (if you have one) . its a switch on your clutch pedal.
Ignition Wire Location
