NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue May 17, 2005 4:49 pm
I had a guy come in today, he towed his car from another shop, the shop told him his compression was low and noted the compression readings across the board. I think it was 92 75 64 125. They told him it needed a new motor.
Now the reason he took it to that shop was it would not start after it was driven to X location upon leaving an hour or so later it would not start. Car supposidly ran beautiful on the way to X location.
I get to the car in the parking lot plugs are out and cap is off. The owner of the car walks up to observe, we converse as I work. I think hmm lets throw it back together and hear it whine while cranking, cause after all there is next to no compression. well I get it back together and crank it, well dang it sounds like it wants to start?? how can it have no compression. So I pull the cap back off and take a close look at it, Hmm this cap ,the other shop had off, has a very obvious crack along the coil trace coming from the edge of the cap,as well as a little oil in the crank angle sensor part of the distributor assembly, Not quite enough to be a problem but there is oil in there none the less. I tell the guy I feel a cap will likely get it running. But I caution him that the oil getting in there can become a problem if enough of it gets on the crank angle sensor. Due to his uncertainty the OTHER shop has instilled in him he wants to just go with the cap and rotor for now to see if the car really will start. So I go to parts and get him the $30 in parts[much less then a $4000 engine overhaul] I have him see the advisor to sign the estimate, I remove the made in taiwan cap and rotor and install the factory cap and rotor. hold my foot to the floor and she came to life with a bit of a sputter due to the amount of fuel in washing down the cyclinders that can cause lower compression and give you false readings if you dont remove the fuel pump fuse when doing a compression test as the other shop obviously did. After the fuel cleared out the car ran as it did when they were on the way to location X. He had it towed to us because he was smart and realized the after market shop had no idea what they were talking about.
And finally my point. The shop working on your car obviously is lost and doesnt know for sure whats wrong and is taking guesses trying to use your wallet to pay for their training. Maybe you outta consider taking it to someone more competant.
