90 240sx SOHC Hatch Starting Problems.
MiddMackAttack
Car: 1990 Nissan 240SX SE Fastback
Yesterday I took my steering wheel off, and most of my trim around it. After I put it all back together, i got in my car, and it started and took off, it started without any hesitation, and I didnt have any problems. This morning, i get in to warm it up, and the key turns all the way, but I am not getting any noise at all from the engine, not even a clicking, or a begining of a start, I tryed jumping it with no luck. anything else I can try? im really frustrated and annoyed, thanks.
BlackHat
Car: 1989 Nissan 240sx Hatchback
I just got done removing and installing all of the steering wheel stuff as well as the dash, the only thing I can think of is to double check the connection to the key cylinder... did you take that off?
navysnail
see if the starter is getting power when you turn the key. you can also hit the side of the starter and see if that helps it.
