90 240sx se auto STARTING PROBLEM
Lamarossa
guys im new here
sorry i try search for 240sx starting problem and found nothing
i have a 1990 240sx se auto
new plugs, wire, cap rotor, and alternator
BATTERY OK
CRANK OVER OK
crank over but no starting sometime, especially when the engine is hot
car idles ok,
problem: under 2000 RPM and when the gas is to the floor , car sputter, RPM drops almost want to stall,
then if i back off the gas it will run ok
no power whats so ever
im thinking throttle position sensor or is there a cam position sensor or crank shaft sensor ?????????? i heard is a common problem
any help would be greatly appreciated
thanx guys
Lamarossa
ricebike
2002 Quest
2005 Altima
i'm guessing u checked the electrical connections & made sure those new parts are in working order...
mebbe fuel filter time?
did u pull trouble codes to see if it is any of those sensors/circuit wires are bad?
http://www.240sx.org in the FAQs section should give u some instructions/codes if u dunno how to do it.
GL!
Lamarossa
New fuel filter
Lucas Fuel cleaner
New Plug
Wires
Cap & Rotor
runs a bit better
still have hot start problem and no power
ricebike
2002 Quest
2005 Altima
time to test starter/wires to it? heat goes up= increased resistance... just a possibility...
no power problem <shrugs> any trouble codes stored in the ecu?
