I think he had started another thread elsewhere and a mod moved it back to RWD SR. I merged the threads and deleted the dupe post.nzmoman wrote:why did you start a new thread on this with the exact same thing when your first thread is still open and on the first page.
no, i prefer actually doing some work and then asking questions when i need to. i guess you aren't allowed to ask questions on forums anymore or somethingduffman1278 wrote:Sigh, you havn't read up on SR swaps much have you? YES you cut the dust boot.
compression i belive was 125-150 i think it was 125 thoidk which fuel pump but i kno it cant be stock because its loud as **** and it squirts fuel out like crazyidk what the fuel pressure it at. but when i pull the plugs out they are wet so i kno tht it is getting fuel... also now that have fixed the knock sensor harness when i try to start it, it back fires and sputters alot. i looked for codes on my ecu but there was no switch or led in the hole in the ecu.. it was just empty. i replaced the ignitor and i now have a bright blue/ white spark.duffman1278 wrote:Seems to me like there's somethings you're not checking because pretty much everything that's been stated is what is needed to start the motor. There's really not much else. I dunno if you're over looking something or what but it has to be one of the following issues. Compression, spark, or fuel. Thats pretty much all you need to start an engine.
What were your compression numbers?What fuel pump are you running?Whats the fuel pressure at?Have you tried checking the ECU for codes?Have you tried another ignitor?Are you sure you're getting fuel through?
Search up on Nico or other forums and DOUBLE check your vacuum lines. Also, look down into your cylinders through the spark plug hole to see if you've flooded the engine. Let the fuel evaporate.
