pgtrr wrote:'90 240SX S13 Driveline/Clutch Question?
1) On the driveshaft - what is the best or recommended point to separate it from the tailshaft of the transmission? It's some sort of 2-piece arrangement w/ a center 'joint' mounted to the chassis. Do I simply unbolt it at the differential, drop the center piece bracket and slide it out of the transmission tailshaft?
2) Is the pilot shaft gizmo a 'bearing' or 'bushing' on this car and if it's a bearing is there any trick to getting it out of there? I cannot ever seem to find pullers small enough. Bushings usually come out for me w/ the grease trick.
3) Is there a seal on the transmission shaft that is recommended to be replaced?
4) Anything else I should do while I'm putting a clutch kit in?
5) Any particular brands or kits folks like or warn to avoid? - nothing performance for me - just good OE type new quality is all - maybe Back-Arnley or something similar.
1) at the joint where the 2 drive shaft peices connect
2) on my 1991 it was a bushing type, i don't know bout the sohc's
3) the Rear extension housing seal, where the drive shaft enters the transmission
4) check the rear main seal behind the flywheel
5) Napa makes good parts, if your going for oem than napa is your best place to shop, i got my complete exedy clutch kit off of ebay for cheap, i'm satisfied.
