gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Sun Apr 17, 2005 7:32 pm
I just took another drive around town. No overheating or running warm as I never went up a steep hill. I did notice that the idle would slowly creep up at a stoplight but I'd hit the accelerator to bring it down once it hit 1200rpm. It seemed as if the idle was going to keep going higher and higher.
When I got home, no boiling. However I did notice the reserve bottle was lower than it had been earlier today, but yet I saw no leaks in the system. I also felt the upper and lower hoses again.
I could only touch the upper hose for a second and then it was too hot. I grabbed the lower hose, and while it was hot, I could easily hold on to it. I went back to the upper hose; too hot to hold. I also touched the radiator cap. Is it supposed to be hot too? I'm not sure, but it wasn't even warm.
Your flow problem theory is starting to make a little more sense out of my problems. I did use an OE aftermarket thermostat (I believe - I have to check tomorrow to verify). I did notice that the radiator said Nissan on it and looked pretty original. Actually, knowing the previous owner (cheap a$$ - cared nothing about the car), if the radiator had ever been replaced 1. it wouldn't have been done at a dealer, 2. it wouldn't be a Nissan radiator.
I figure after 15 years and 120k it's about time to replace that anyway whether or not it solves my problem. Do you know much about CSF radiators? I have a wholesale account and ordered a radiator from them for my buddy (dal2kvvisp nico member). It was a BEAUTIFUL radiator, black and SOLID! I believe it was a performance radiator though.
O/T: Wow I've had this car a month and a half and I've done timing chain kit, waterpump, thermostat, kn intake (big difference at high rpms btw), front struts, brakes & rotors (front and rear), tires, wheels, antenna mast, spark plugs and wires (both ngk of course), fan clutch, and tomorrow I'll be receiving my intake hose, new coolant reserve, and installing rear shocks...and ordering a radiator and new upper & lower hoses. For me - someone who's always had cars and did little to no maintenance (besides on he Q), that's a LOT!
Modified by gniknave at 11:28 AM 4/18/2005
