90 240SX not starting
ShelbyZ
Car: 240Z, 240SX
I've checked and I do have fuel flow coming into the fuel filter. I do have spark also at plugs.
Pulled plugs:
#1 wet#2 dry#3 dry#4 really wet
Just wondering if this is a problem with the injectors or something else that controls the injectors.
New to fuel injection I'm used to working on carbs. So please bear with me.
Thanks,Brian
teddy
Car: Saab Turbo and MR2
What engine is this? Any modifications such as larger injectors or an upgraded fuel pump?
ShelbyZ
Car: 240Z, 240SX
I'm sorry, it's a KA24e that is completely stock. No mods at all.
Thanks,Brian
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
I had same problem, try wiggling the mass air flow sensor thing on the air filter and see if that helps.. (might be worth a try, heh)
vancouverbc
Car: 1991 240sx
From the EF (Engine Fuel) & EC (Emission Control System) section - Diagnostic Procedure #5 / Hard to Start or Impossible to Start when Engine is Hot:** Fuel Pressure - Squeeze the line coming out of the filter and to the engine when cranking the car. You should feel pressure. No = Check the fuel pump and it's circuit. Yes = Continue
** Check Fuel Vapor - Disconnect fuel pressure regulator vacuum hose and plug the hose. Can you start the engine? Yes = Check fuel properties (don't know what this actually means) No = continue
** Check Injector - Remove crank angle sensor (distributor) from engine. Be sure to note the location and orientation of the rotor before taking the CAS out of the engine. It needs to go back the same way (Crank angle sensor harness connector should remain connected) Disconnect ignition coil harness connector. Turn ignition switch on (Do not start engine) When rotating crank angle senor shaft (distributor), does each injector make an operating sound? No = Check injectors and circuit. Yes = Continue
** Check Ignition Spark - Disconnect ignition wire from installed spark plug. Connect a good known spark plug to the ignition wire. Place end of spark plug against a suitable ground and crank engine. Check spark. No Good = Check ignition coil, power transistor unit, and circuits. Yes = Continue
Check ECU Harness Connector
Check ECU Power Supply and Ground Circuit.
Basically, what's being looked at here is if the engine is getting fuel, the injectors are injecting and the spark is sparking. The ECU part is standard fare in diagnosing our car.
ShelbyZ
Car: 240Z, 240SX
Thanks for the help guys!
I've got her figured out now. I am going to print this out so I have it for future needs and ease of accessiblity in the garage.
Thanks,Brian
