slideways13.4 »
https://forums.nicoclub.com/slideways13-4-u125680.html
Sat Jan 31, 2009 6:39 am
i dont remember if the 240's have 5 bolt or 6 bolts that connect to the axels but i know that j30's come with both styles so if you want to make it easier on ur self find the j30 what has the same patter because if not then you will have to use the j30 axels also. you will have to take off your 240 cover and put it onto the j30 diff and you will also have to use the j30 bolst and shims to connect to the chassi. if you do not use the j30 shims eventualy the diff with break!!! and vibrate like crazy
so= j30 with same axel bolt pattern with j30 bolts and shims 240sx cover
make sure if you change the fluid to also put lsd additive
