blacksrjdm »
https://forums.nicoclub.com/blacksrjdm-u52167.html
Fri May 15, 2009 9:44 am
So, ok, tapping sound on a KAT with a smoking problem.
Is it tuned?What was the compression?How is the idle?Is it overheating?Have you tried swapping ecu's with someone?Is your check engine on?How many miles on engine?What kind of turbo?
A HORRIFIC TAPPING sound is normally what I would go after first. Unless that is just the chain guide. But, if it isnt the chain guide, then the horrific tapping noise, just might be the issue. I would remove the valve cover and see if you can see anything loose, broken or otherwise. I dont think at all that this is an electical issue. Also, could be leaking injectors. Not unheard of to have all four go bad. But, not likely. Could even be that the turbo is shot. But I would start at the tapping and go from there. Tapping is never good.
