90 240SX KA24E - Really high oil level
ii_cantwait
Car: Gray 1990 HS13
The car has about 108,000 miles, 5spd...I checked the oil dipstick and for some reason the oil level was way above the 'H' mark. is this normal, is it bad for the engine if i keep driving like this? what could be the problem. Btw I didn't add oil to it at all it just happened recently.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
I have the same model as you, and sometime it takes me a few tries to get the correct reading on my dipstick. Did you recently have the oil changed or change it yourself?
If you do your own oil, I'd suggest changing it and just filling it to the proper level.
NISTECH
also make sure your checking the oil with the car off, not running
ii_cantwait
Car: Gray 1990 HS13
gniknave wrote:I have the same model as you, and sometime it takes me a few tries to get the correct reading on my dipstick. Did you recently have the oil changed or change it yourself?
Nah, last oil change was at 107k mi. and I don't change the oil myself.
ii_cantwait
Car: Gray 1990 HS13
NISTECH wrote:also make sure your checking the oil with the car off, not running
indeed i do. I usually check it in the morning to make sure all the oil has settled overnight and get the most accurate reading.
NISTECH
assuming the oil was filled properly when it was initially added ,The only way the oil level can climb is if another fluid ads to it, typically its fuel. Are you having any drivability issues?
ii_cantwait
Car: Gray 1990 HS13
NISTECH wrote:assuming the oil was filled properly when it was initially added ,The only way the oil level can climb is if another fluid ads to it, typically its fuel. Are you having any drivability issues?
I see..well my injectors are leaking but even back then the oil level was still normal....As far as drivability, nothing seems out of the norm...Just wondering, how exactly can fuel mix with oil?
NISTECH
it washes down the cyl's and gets in the oil. You usually see this when a car is flodded. The fuel bypasses the rings.
djl601
did the problem was fixed? i have the same problem too.....can someone please tell me what happened and what should i do in the same situation??
my oil level goes real high after turn on.....and white smoke came out from exhaust.....but when the engine colds down....the oil level went back to normal....
what happened there.....help please...
