90 240sx ka needs cold air intake .. where can i find one
neongreenglo
Car: 90 240sx fastback
i just baught a 90240sx with sohc and i cant find a cold air intake all i can find is adapters and other stuff but no cold air i found em from 91-94 but they have dohc where can i get one
nissilvat
Car: 1990 240sx
you can get one from injen, where i got mine, or go to a local muffler shop they can make one
neongreenglo
how much was ur injen cold air intake
nissilvat
Car: 1990 240sx
i got it for 150 i think, which if i knew then what i know now, i would of just had one made. it'll be half the price and still finction just as good. also mine was a short ram, and i fount this intake at autozone for a honda, which with a ruber 45 degree street elbow i fabricated into a cold air intake extension directly behind my left turn signal. ill post pics soon, for references.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
I have to agree. i have a 89 nissan 240sx fastback and i cant find one, so i am going to make one from 3 inch piping and 45 and 90 degree rubber elbows. I will check back for those pics for help.
Modified by nelson8708 at 3:47 PM 12/26/2004
neongreenglo
thanx everyone that has replied lookin forward to those pics ... later
89 240 SOHC
Car: 1990 Micra S13....Micra with S13 Seats and other S13 accents to follow
Where do I stick the MAF and Air Temp Sensors in my cold air intake? I have it behind the Right (passenger side) head light....moved the battery to the left side.
nissilvat
Car: 1990 240sx
you might have to extend your wiring if your putting it on the right side. if its custom made, you could make a mounting base of of epoxy putty and mount the maf onto that base, similar to the way it's mounted on the stock intake, and the temp sensor you can drill a smal hole to mount that in.
guamka24de
Car: 1993 240sx fastback ka-t
i relocated my battery and intake. i used a 92 civic pipe and used connecters. i also had a hole in the fender well so thats direct air from the from the vent on the bumper. noticable difference.and also louder sucking sound.......
scruffy63
Car: my nissan 240sx
ok first of all I have to say the soch does not by any means have better internals than the dohc they just have different compressions. the sohc is just a little easier but in general the dohc is better.
keep the maf where it is supposed to be somewhere before the hoses on the intake pipe. those hoses need metered air.just leave it right after the filter.
just make sure the air temp sensor is placed close to your filter.
you don't have to extend any wiring.the wiring actually starts around the throttle body.so it is more than long enough.
