90 240SX KA ENGINE HARNESS
5spdcontained
Car: 1990 Nissan 240SX SOHC
I have one question. I need to replace my ka24e engine harness. It's garbage now. I was wondering if its worth buying a ka24de engine harness for my ka24e and if its compatible? Fuel injector plugs, ecu, knock sensor you know, etc etc.
centralcoaster33
Car: 1997 Nissan 240SX #5
Hey and welcome to NICO Club!
I don't think what you are saying will work without significant modification. A lot of the plugs for sensors and components are keyed (they only mate up to a specific sensor) and the sensors change with engine redesigns (ie distributor and position sensors). Also, it sounds like you're referring to a RWD harness vs FWD which wouldn't work (I could be mis-reading). By rotating the engine 90 degrees, you end up with different lengths of wire to get to the sensors or components. Wiring Specialties is pretty good with harnesses and you might be able to get bits from them to rebuild your current harness. Or just shop around for a used one that is correct for you make, model and year.
PapaSmurf2k3
Site Admin
^Not sure how you figured he'd be getting anything FWD... I'm pretty sure he's just talking about replacing it with a 91+ KADE 240 harness.
But yeah, unless you're upgrading the engine and ECU at the same time, you need to stick with the correct harness for your engine.
centralcoaster33
I get things mixed up sometimes! :crazy: I just noticed the subject title was 240sx KA harness and his car in the signature is 1995 Altima... :gotme As I said, I could be mis-reading. I hope it's understandable to the OP.
5spdcontained
thank you, both of you helped out. and yes I have a 90 240sx rwd, and a fwd ka24de Altima. ironic but I miss the 240 and need it running. thank you, ill probably look more into rebuild kits for the harness if I cant find what im looking for in my price range.
centralcoaster33
Well, consider contacting Wiring Specialties. They're good. I'm using them for parts to create a harness for my '95 240sx. I got all the plugs and pins from them and need to acquire the wires and put it all together. They do not make an OEM style harness for my car, so I have to build it. It is a ton of work though and if there is a price for an assembled one for your car, I say get it. It seems pricey, but once you spend all the time verifying wire gauge, length and type, then buying it and putting it together, adding loom and testing, the cost of the finished product seems like a great deal. I believe I saw somewhere that they do in fact make one for the S13, so look into that.
centralcoaster33
PS - you might list your second car in your user profile.
PapaSmurf2k3
Site Admin
Yup, I used them to replace the harness in my S13, but its for a DOHC KA. I'm not sure if they make one for the SOHC.
nissangirl74
As the guys already mentioned, contact Yuri at Wiring Specialties. He is the guru. Mention NICO when you contact him.
http://www.wiringspecialties.com/
centralcoaster33
Yeah, Yuri helped me over the phone quit a bit. Great customer service.
5spdcontained
Alright. im still trying to figure this site out but I will add my other car. And I will take a look into wiring specialties, I seen one for 350 but when you put it like that, its not that bad. thanks for the advice!
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Topic moved to the 240sx forum.
