90 240sx Idles too High
ADF932
Car: S13
Recently my car has been idling around 2,000 RPMs and of course its been wasting alot of gas lately. I was wondering if the Throttle Sensor is giving out or i need to adjust the Idle speed screw? I cant find were the Idle speed screw is located.
tonynalli
Dont go playing around with the idle adj screw. You will make things worse. You have a different problem with your car. There is a chance the tps sensor is going bad. Also, check vaccum lines and connectors. AIV might have some malfuntion..
