dope240sx wrote:My car is idleling at 1200 was at 1500 when it should be like 750 when i accelarate the rpm drop and then go up i squeezed the line that goes to the air regulator and iacv and the rpms dropped i squeezed the line where it connects to the intake tube also it didnt want to start because it had to much fuel in the engine is it because bad injetor(s)?sometimes i would move the 1 injector and the rpm would drop a little
Can anyone help me?
I think i fixed the problem my coolant temperature sensor did not have a good connection i cleaned the plug and the sensor and now it responds without the rpms dropping then rising and idle is at 750 to 700 now
I hope this was the problem
i checked this sensor because i saw it in a different forum and the guy had the same problem
