90 240sx : Hey I need a little help on the final step of my ka24de swap!!!!!
guyin180
Car: 97 s14 kouki
Hey I got a 90 hatch with a ka24de swap in it ..... I got the motor dropped in it now I need to attach the hose and wires..... Thats the thing, I can't remember what hoses goes with what? What hoses do I need to hook up and to what? I hope that this is all I need to make the ka run.......
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
What you need to do is give us pics of it. Then you need to go out and buy a manual, that has all of the mapping of all of the hoses and wires. But still give us some pics so we can try to help.
180fan
Car: 89 fastback
heater hoses at the back firewall, ps lines from the rack to the ps pump, radiator hoses to the coolant elbows off your motor to your radiator, ac lines if you popped em off runs from your firewall to your ac compressor, fuel feed/return from your fuel filter and the long rubber hose next to it to your fuel rail, intake piping (if you need this one's location you should be shot), most of the plugs will fit in one way and will go to the stuff on your motor that are in the vicinity of where the harness takes it ie you should end yourself if you're trying to put a MAFS plug on an injector and wondering why the ps plug isn't reaching the sensor on the hose.
