CJams »
https://forums.nicoclub.com/cjams-u162407.html
Tue Aug 10, 2010 11:32 am
History:
- Engine blew (4 years ago) 90 hatch
- Replaced both engine and auto trans with good engine and manual trans from wrecked '90 hatch.
- Good engine and trans worked fine right up till we pulled it.
- Swap went well. Jumpered the wires together on the top plug behind the fuse box in engine bay. All threads say the car should start. But It doesn't.
- When the key is turned all the way to start the car everything goes blank as if the clutch isn't pushed in. There's nothing.
- So I don't think it's the manual swap wiring stopping it. This car hasn't been active for 4 years so I thinkit may be something else. ie: missing fuses, relays, etc..
- I tried the ECU troubleshooting and got this... turn on ignition, turn ecu knob fully clockwise and it blinks one, then 2times, then 3, then 4, then 5. I let it cycle like this 4-5 times and then turned the knob back counterclockwise. When turned back counter clockwise both the red and green lights come on and stay on for ever.
- The manual says to check all the wiring, i did and everything seems to be plugged in.
Does anyone have a better troubleshooting tree/method to figure out where the faulty wiring is?
Any suggestions?
No wires are currently connected from the manual transmision to the car. And we are still using the auto trans ECU.
Any help would be greatly appreciated.
