OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Wed Nov 04, 2009 1:27 pm
from my tech tip in the technical section
BOTH THE BATTERY AND ALTERNATOR CHECK OUT GOOD, BUT AFTER A FEW DAYS MY BATTERY DIES?
Parasitic battery loss is the technical term for this problem. It is caused by two root factors.
A – A circuit or device in the car that stays on drawing current. All cars have circuits that do this such as the ECU, clock, and headunit memory. Those items are not issues usually, unless something breaks down in these devices causing them to draw more current. But if you have added new devices like amps, caps, engine electronics, they could be wired incorrectly causing them to stay on all the time. The other thing that can cause this to happen a nick in a harness shorting to ground. It may not be a hard short due to a painted surface, but if there is a current loss you will drain the battery.
B – The other thing that causes this… A leaking battery. When a battery drips or leaks it leaves a trail of electrolyte down the side of the battery. The chassis is grounded so if the battery is leaking a little (like a single drip that runs down the side of the battery) it will make a trace to ground. Kind of like a tiny solder trace on a board. Current flows down this trace to ground causing a small but steady discharge of current. If your battery is leaking replace it. If you have wet mark around the terminals or green fuzzy looking stuff known as copper sulfate on the terminal replace the battery and cable.
