its not really a squeal, its more of like a constant squeaking...as the car moves faster, the squeak goes faster as well..i havent tried the brake quiet stuff yet but thanks for your input though240kid wrote:you could check the brake pads, although when they are worn they have more of a squeal and it would increase when you hit the brakes. you could try that brake quiet stuff, as the squeal could be coming from a pad as it touches the rotor and there is nothing to keep it from resonating.
there was somthing else that i was gona say to check, but i cant remember what i was going to say.
oh ok ill try that, im not really experienced when it comes to cars so can u specify what exactly needs to be cleaned?? thanks!s13sr20chris wrote:just give her a good brake check. pull the wheels and poke around. clean them off with brake cleaner.
