90 240sx fastback power window fell
smag
One of the power window just dropped into the door. I checked the door but really can't figure out where to start and how can I take the shell off to see the window. Any suggestions are appreciated!
benemorius
Car: s13, s13, eg, e36
There is one screw in the door handle and one behind a cover toward the front. Remove the plate around the lock and lever. If it's the passenger side then you must also remove the oh-**** handle. After that the whole door panel pops off and lifts up. That's probably a pretty crummy description but I bet you can find a better one if you search. I know for a fact I've given better instructions in the past.
You're probably looking at a broken regulator cable.
