pgtrr »
https://forums.nicoclub.com/pgtrr-u10140.html
Sun Aug 06, 2006 6:37 am
I've got a 90 240SX with a KA24E S13. It's a very original 140kmi 1 owner car w/ no mods. The mediocre wiring diag I have doesn't include colors so I'm looking for some add'l help here.
Recently I've been chasing out a water leak where it was boiling & dumping water after shutting off and it now has a new set of hoses, clamps, tstat and cap. Seems to be OK so far (knock on wood) but that's not what I'm posting about...
Even while idling with the AC on max in near triple digit ambient temps and an increasingly lower that optimal radiator water level the temp gauge NEVER inched above halfway which surprised me. But when I'd shut it off the water would be boiling in the radiator and overflowing through the tank (thus bringing the rad level down). Also the auxiliary elec fan on the radiator never once kicks on. I don't know that it ever has. So I'm starting to wonder about the gauge, temp sending units and what not and want to make a few add'l checks before closing the books on this project.
Questions:
Q: Where is the temp sensor located on the engine that controls the DASH temp gauge?
Q: Does it ALSO control the aux ELEC fan?
Q: If not, WHICH ONE does and where is IT located? (I found one odd sensor spliced into the bottom rad hose near the rad)
Q: What are the 'CONDITIONS' that trigger turning on the aux elec fan on the radiator?
Thanks
