Soy »
https://forums.nicoclub.com/soy-u13809.html
Mon Feb 27, 2006 6:45 pm
WD-40 for the win! Get a can, and soak the lock in it. Wait a few minutes, then lock and unlock the car a few times from inside, then with the key from outside - should get everything moving.
If it's still sticky and tough to turn, you may need to inspect the lock mechanism - pretty easy once you pull off the door panels - just fiddle with the lock and lube it up. (Get your mind out the gutter!)
