90 240sx Diff axels???
trigger94587
Car: 90' 240sx Coupe
Ok heres the problem, my car clunks when im going to bumps and rocky bumpy roads but not on a straight roads. So I put some sub frame collars on it but it dosent help. then I rise my car and move everything below my rear sub frame. and when I try to move this (shown on the picture) I can hear like clunking and its moving. Do u think its normal? or its the one causing the clunk sound? How can I fixed it? Thanks!
180fan
Car: 89 fastback
It's coming from the diff on that side or is it flat out from the axle? Open diff as well?
mr2lickit
Car: looking
Clunking is a hard noise to distinguish haha. Ummmm it could be your springs compressing. I know this often happens with aftermarket suspension. If its a constant thump it could be a bad rear hub. If you accelerate hard (jab the gas) and you hear a clunk it could be your diff locking (which is normal). Besides that just make sure none of your bushings are going bad.
180fan
Car: 89 fastback
on an open or vlsd it shouldn't make a clunk. When I put in my subframe bushings, I can clearly hear a clunk. I'm already certain it's from the ring gear getting worn which makes me want to go emo. I hope you don't have to go emo with me. *sets a box of razor blades and a hawthorne heights cd next to me*
trigger94587
180fan wrote:It's coming from the diff on that side or is it flat out from the axle? Open diff as well?
Its from the diff
trigger94587
mr2lickit wrote:Clunking is a hard noise to distinguish haha. Ummmm it could be your springs compressing. I know this often happens with aftermarket suspension. If its a constant thump it could be a bad rear hub. If you accelerate hard (jab the gas) and you hear a clunk it could be your diff locking (which is normal). Besides that just make sure none of your bushings are going bad.
I have coilovers, How can i fixed it if i have a bad spring?
trigger94587
180fan wrote:on an open or vlsd it shouldn't make a clunk. When I put in my subframe bushings, I can clearly hear a clunk. I'm already certain it's from the ring gear getting worn which makes me want to go emo. I hope you don't have to go emo with me. *sets a box of razor blades and a hawthorne heights cd next to me*
Ring gear?
mr2lickit
Car: looking
If its the springs then its nothing bad, but if you want to get rid of the noise you can buy spring wrap thingys lol (it looks like thick tape that you put around the springs).
180fan
Car: 89 fastback
yep they've got noise reducing stuff for springs. It looks like a wrap on your spring.
It's from the diff, you may be in for it just like I am.
trigger94587
Where can i get a spring wrap? and how can i install them? i think i have to compress the spring right?
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
HAHAAHAH man i feel u! i felt like goin emo earlier cuz i found a new scratch on my car its about a 1/4 of an inch, but still!!
