ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Mar 09, 2008 6:46 am
it's too easy to reply, but here goes...
any CAT would be ok, just keep a copy of receipt and when it was installed in your glovebox... the only thing illegal is the test pipe or a hollow CAT...
process is fairly simple; just 4 bolts... however if it's the original bolts, it's probably seized up there by now... and will be a major PITA to take off
on my car, i had to use a small dremel tool & like 10 cutting discs to take them off & install w/ a bolt/washer/ lock washer/ nut
if u go for a CAT w/ a "universal fit" and no oem-style flanges, then u will haveta get a shop to weld em on
