slidecrave »
https://forums.nicoclub.com/slidecrave-u47700.html
Tue Mar 27, 2007 10:37 am
alright first i just wanna ask if anyone has heard of using a tractor battery in a 240.. cause i just got this coupe and the previous owner was using one, the battery doesn't seem to be the problem just curious if anyone has done this?
Now the problem I'm having is that I go to start the car, key in everything turns on just fine seat belt goes back, then I try to turn the car on and everything just dims out like it lost power and the engine hasn't even moved a bit no crank or anything. So i checked all the fuses, none of them seem to be burned out and I checked that button around the clutch pedal to see if that was it and nope, even pushing it in with my finger made no difference. I thought ok maybe the battery doesn't have enough power to get it to start so i get a buddy of mine to try to jump me and we connect the cables and so on and nothing has changed. So i dont really know what it can be.. Anyone have any ideas what i should try?
A CA has been swapped into it, but I got that all running and starting up and drove it around a couple times before this problem happen so I don't know.. On the other hand there was some engine start button that the kid before me had wired up, which I'm not really sure how he wired it and i only found out what it did when I started messing with it and clicking it and then i held the clutch in and click it and the it started my engine, later on i did it one more time to show a friend then drove home. The next day when i went to try it and start the car is when the problems started so idk if maybe it has something to due with it or not.. maybe the ecu got fried cause how it was wired..? I don't really know I'm an idiot when it comes to electrical stuff.
I know its long but I dont know what else to try.. And I figured the gods on nico could help me out
Modified by slidecrave at 4:05 PM 3/28/2007
