Dukemoney63 wrote:ok i just bought a 90 240 w/ a redtop sr20the car will die at very low rpm, not idle, but if i give it a little burst of gas and then completely let off and push the clutch in the engine will rev all the way down to around 200 rpm everytime and sometimes kill
What are the specs on your car? Is it stock red top? What kind of engine management, injectors, etc, etc. We can't help you w/ little to no information.
If the only difference between your setup and a stock sr20det is the bov, then you should at least be able to idle, otherwise you have some serious leaks.
The part w/ the burst of gas & open bov is probably because the ecu is not tuned for open bov. If you don't understand what I just said, I strongly suggest reading the threads & stickies in the turbo sections.
I hope you know how to do basic work/diagnose on turbo'd cars... If not, start searching & reading the stickies.
