90 240 spark from coil but no spark to spark plug wires
240brandon
Car: 90 240sx
1990 240 SOHC Ok so i have spark coming out of my coil going to distributor but no spark comes out of distributor to spark plugs wires i already changed spark plugs, plug wires, cap and rotor, distributor assembly, coil, power transitor, pcm, coil has 12volts took all those parts from a buddys car that runs perfect and my car still does the samething
themadscientist
Have you confirmed the rotor is spinning? Pop the cap off and crank the engine. You seem to have covered everything else.
