180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Mar 25, 2006 10:21 pm
Slushy oil around the valve cover? 1. is your valve cover leaking? 2. burning blue smoke, you could have worn valve stem seals or bad rings. 3. hesitation, have you tried a tune up firstly, secondly are all your fluids in check, when you changed your transmission fluid was it really sparkly? 4. your clutch pedal to the floor, find the leak and fix it. This is simple enough, there aren't many places it could be leaking. Bleeding procedures can be found with a search.
