qwikxr »
https://forums.nicoclub.com/qwikxr-u51866.html
Tue Dec 26, 2006 12:21 pm
I installed a cliamte control (push button), AC section and blowerbox today, since the p.o. removed all of that stuff..
Well, got everything installed, and the blower works (makes racket, but it works for now.) The issue I am having is that when changing selections on the climate control, the selection changes andd that button illuminates, but the airflow does not get redirected. Seems to stay on floor setting, regardless of setting selected. Both plugs are plugged into the control, the blower is plugged in, and the 4-wire plig is plugged into the AC portion of the box.. The only thing that isn't plugged in, is the 3-wire connector for the temp sensor in the AC box.. The plug was cut off of the harness, so I'll need to get one.. I doubt that this 3-wire plug is the issue for the door flaps not working, but I don't know..
Any ideas are appreciated.Rick
