Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Apr 11, 2007 10:34 am
what compression does in a cylinder is squish the fuel mixture more. the more you squish it, the more that mixture will push down on the piston when you ignite it. That's the basic, layman way I can describe it.
In non-forced induction applications, raising the compression of the pistons is a great way to get more horsepower out of a motor. In forced induction applications, you have to be careful. If you raise it too much, you run the risk of predetonation if you run too much boost. The reason is that you're compressing compressed air, and compressed air likes to heat up, and if it heats up enough in the cylinder, it'll light off without the help of the spark plug.
The big benefit you'll notice with running a slightly higher compression is more bottom end in power output. Of course, being the double edged sword it is, you'll limit top end some, but I think for a balanced motor, 9:1 sounds good.
Once you have the motor rebuilt and running, let us know how they run and try to get some dyno pulls to post up some empirical data.
As far as tuning goes, that's what dyno time is for. If you have any way of augmenting your A/F control, dyno runs will be the best way to optimize it, as well as positioning of the ignition timing.
