9.6/1 AFR at idle WTF
WDRacing
I can't get the car to lean out...at all. I even have the fuel pressure at 20psi. The SAFC is set to -50 and I don't get any change in AF mix.
With the key in on, I get 3.4 volts from the MAF, can that be correct? I'm so tired of screwing with this car. I may just get rid of it and buy an old Nova with a big block and a carb.
Any idea's/thoughts on where to start troubleshooting?
Tictakman
not that im gonna know whats wrong.... but what is ur fuel set up that ur running?
Zak
Structure240sx
what are you in/out settings for the maf? do you have a good ground for it (z32 maf)? did you setup the dec. air settings?
WDRacing
I used the same settings you did for the in/out, 2 and 6 I believe. The 300ZX maf has 2 grounds correct, one that goes to the 240 maf harness and one that goes to any ground on the car correct? Cause thats the way I have it.
Anthony, why don't you just fly out here real quick and fix my car. I'll buy ya a beer...lol.
Oh yeah, I blew my turbo oil pressure line, so I sprayed about 2 quarts of oil all over the ****ing place. I already fixed that, but I have to clean up still.
The Dec. air settings I also stole from you.
skatanic28
Car: 96 240sx
i think i get around .5 volts before startup, something is definately messed up with your mafs. some people have used 1/6 for the hotwire settings, maybe give that a shot.
skatanic28
Car: 96 240sx
WDRacing wrote:The 300ZX maf has 2 grounds correct, one that goes to the 240 maf harness and one that goes to any ground on the car correct? Cause thats the way I have it.
not sure if this would make a difference, but the rewire stuff i saw for it tied both the grounds together and tied it to the mafs harness.
Import_Ant
http://srownersclub.com/faq/faq_mafs.asp
the wiring for the MAF on the KA and SR harnesses are the same.
they show a wire needing to be grounded to the chassis...
Nismo_Freak
Car: 89 Nissan 240SX
WDRacing wrote:I can't get the car to lean out...at all. I even have the fuel pressure at 20psi. The SAFC is set to -50 and I don't get any change in AF mix.
1. MAF voltage too high, re-evaluate the wiring
2. You can lean out the mixture by turning the idle screw to some extent
Structure240sx
the in/out settings that are really suppose to work are 2in 5out (2=z32 maf 5=240sx maf). i have heard there are actually two different types of z32 mafs and i have alos heard this is a rumor (n61 and n62). 1in 6 out jsut works better for me. try 2in 5out. i went through a bunch of different combonations until i decided on which was the best for my car.
the technically ture 2in 5out setting for me would make the car run pig rich exactly like yours i believe
240SicknessX
Car: 96 240 SE
Nismo_Freak wrote:1. MAF voltage too high, re-evaluate the wiring
yes mafs voltage is too high with key on, from the fsm.......
-Ignition switch "ON" (engine stopped) less then 1.0 volts-Idle (engine at normal operating temps) 1.3-1.7 volts-Idle to about 4,000 RPM, 1.3-1.7volts to approx 4.0 volts
Check for lenear voltage rise in responce to increase engine speed till 4,000 RPM
remove mafs, and check hotwire for damage or dust/grime.
WDRacing
Thx guys, I'll be rewiring everything in the morning. AGAIN.....
240SicknessX
Car: 96 240 SE
sure thing, just reinerating something you already know and for the ppl that didnt, correctly soder any electrical connections, especially ones that are sensing current, you wouldnt want any other reistance in the circuit, could\will throw off readings. and add some shrinkwrap to make the connection a lil more water resistant.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
240SicknessX wrote:sure thing, just reinerating something you already know and for the ppl that didnt, correctly soder any electrical connections, especially ones that are sensing current, you wouldnt want any other reistance in the circuit, could\will throw off readings. and add some shrinkwrap to make the connection a lil more water resistant.
Yeah WD, what he said. I thought about that after I talked to you today. If you don't solder all the wiring, you can loose current through bad connections which can cause some seriously nasty things. Not sure if you crimped or soldered, but definitely solder anything that has to do with fuel management.
Jookmasta
also check the throttle point on the safc. u probably already have the low throttle point at 0% but it should b at 0% for the safc changes to affect ur AFRs
Structure240sx
Jookmasta wrote:also check the throttle point on the safc. u probably already have the low throttle point at 0% but it should b at 0% for the safc changes to affect ur AFRs
i used to think the same thing, but this is really how the safc works
say you have low throttle at 20% and high at 40% (this is what i have i believe.
anything under 20% and it runs the low mapanything from 20.1-39.9% is a mesh of the two mapsanything above 40% is jsut the high map
WDRacing
I soldered everything that wasn't chassis grounded. But I'm about to go recheck all the connections.
Jookmasta
i think ur right structure......i was playin around with the safc on the highway today and i had no change on the inaccurate narrowband. it is possible that the throttle points could already have a preset "map" as to what percentages correspond to which map we put in. i guess then we really only have control of the maps and not when they kick in?
skatanic28
Car: 96 240sx
Jookmasta wrote:i guess then we really only have control of the maps and not when they kick in?
im not really sure what you mean. you can look at what correction factor the safc is operated at while you are driving, and youll see that below the low-th point you be operating off the low map. what structure said is definately right.
