****BOWS IN HOMAGE*****hay RJ..here is another with great advice!..we definitly need to see you more on the forums bro..excellent words of wisdom...kinda feel stupid not saying it first..lolcarmo wrote:Stock compression is okay depending on how much boost. I seriously would not recommend 30psi on the stock internals. The real issue is good fuel and proper tuning. Doing a bit of research and finding a trust worthy machine shop should be a top priority.
You are refering to NissanFanatics build(S). He loves advertising his record breaking stock block Ka's, but he forgets to add important details. Hes blown 11 or so engines(in one way or another) and bent rods 4-5+ times. So sure you can run 30 psi your just going to trash your rods over, and over, and over again.TrippLives wrote:my whole idea was to keep 9.5:1 because Ive seen 30PSI run on stock internals (9.5:1)
