9.1 1 compression Should I feel lucky
slakker
Car: Cars and Comps
I was wondering if their was any difference in the hp or tq between the early higher compression sohc and the newer lower sohc. other than the extra abuse the engine components take. Does that mean I should run a little better gas. Maybe atleast 89 or 91..Sorry Newb Questions
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
No, and no.
The difference in 8.6 and 9.1 is about 2% total power...not even noticeable.
- Brian
slakker
Car: Cars and Comps
oooohhhhh I FEEL IT! Just kidding. Still though that is a difference. 2% What that is about a k & N filter install. I am already there awesome, I can quit modding now. Thanks though I was curious.
onosqv
Car: '92 240sx Vert
slakker wrote:I was wondering if their was any difference in the hp or tq between the early higher compression sohc and the newer lower sohc. other than the extra abuse the engine components take. Does that mean I should run a little better gas. Maybe atleast 89 or 91..Sorry Newb Questions
The sohc's have different compressions?
Do you know which months/year the lower compression one is?
Thanks .
180fan
Car: 89 fastback
first 6 months of production had the 9.1:1, all else had the lower compressions
:: orion ::
Yes...
the early-89s had 9.1, and the late-89s and all 90s had 8.6.
You can tell the difference by looking for anintake air temp sensor...it was added at the same time as the compression change.
If you seach Freshalloy, you can find a copy of the "Technical Service Bulletin" describing the changes.
- Brian
