Or a rotary... Don't forget themjr_ss wrote:To turn 9k reliably, you'd need full bottomend balancing... I for one would only want to rev to 8k myself, I don't drive an F1 car or a Honda...
Ser200sx567 wrote: Titanium valves are extreamly light compared to stainless steel, only thing is you need to change out the valve seat inserts to a beryllium copper which is also poisonous or toughmet material a copper nickel tin alloy, which changes the machining characteristics as well as the physical characteristics of the engine due to differances in friction and heat dissapation.
Bouncing off the limiter at 7500, yes. Just revving up to 7500 and shifting shouldn't be an issue since that's where the stock limiter is. I personally had my crank balanced at a motorcycle specific machine shop though, so it should be good for far higher than the engine will ever see.PyR0NiAk wrote: People have destroyed heads at 7500 from valve float.
