jr_ss »
https://forums.nicoclub.com/jr-ss-u34795.html
Wed Jan 14, 2009 3:00 am
That isn't the only way to raise/lower compression. Stroking a motor increases displacement, it doesn't necessarily raise it. You need more information to accurately measure the comp ratio you'll be running. Find a compression calculator and use the factory service manual to get all the needed info.
I'm running close to 9.2:1 in my motor because the block has been decked and the head has been milled, effectively raising compression without going to 9:1 pistons.
