But I'm trying to set my timing!fatboy wrote:dont even mess with it
DriftFactory.com wrote:On the KA24E engine (it probably is located in the same spot /area on the KA24DE engine), you have to look at the valve cover from the front of the car. If you look towards the left side of the top of the block, near the cylinder closest to the firewall, on the side of the block you will see a hole with a screw in it. You should be able to stick a phillips screwdriver into it.
if you're messing with the idle screw, get a shop to set your timing. you dont seem like you know what you're doing. sorry if i sound like a d!ckbrokeAs240sx wrote:
